Flexible Conduit connection to shed?
jeffg
Idaho
I had a shed delivered and I want to add some lights to the inside. My meter and electrical panel is about 3' away. I think the proper way to do this would be to dig a trench and bury conduit from the panel to the shed, but would it be possible to just run flexible conduit above ground? There is a fence that I can run the conduit along to protect it a bit.
I am a little worried that the shed is not on a permanent foundation and may move around a bit. Attaching rigid conduit seems like it could cause problems.
Any suggestions?
tulowd
Toronto Canada
When I installed the dust collector in my shed, I needed to run 4" exhaust pipe, as well as 240V, 120V and compressed air into it. Here's what I did, its sealed and angled slightly to allow water to drain off the top/inside if it should ever leak. Ghetto but effective.
J
jeffg
Idaho
No, the space between the panel and the shed is going to be fenced in with a gravel surface. No mowing, no vehicle traffic, and not really any foot traffic except to access the meter and panels. I will grab a picture tomorrow to show you what I am working with.
J
jeffg
Idaho
Here is what I have. I plan on putting a fence from the shed around the power on two sides, so you can only get into it from the front of the shed.
Terry D
St. Louis, MO.
There is no code violation in using LFNC for that application as long as it is supported correctly and not subject to physical damage.
I personally would bury some PVC conduit
Shootinok
Oklahoma USA
For a single 20amp circuit on my shed I just dropped conduit down, added a 90, then went direct bury about 30’ with UF-B Romex. At the shed, back into conduit for a vertical exterior mounted run into a bell box. That gave me an exterior plug, which you already have - so you could use an LB and mount a box inside. I came through the back of the box through the shed wall for interior lights.
I know my shed moves so this arrangement gives me no worries about the flexibility of the connection.
Sent from my iPad using The Garage Journal mobile app
