Flexible power drill extension
gdocktor3
Connecticut
Per description For use in screwdrivers and power screwdrivers.
A power screwdriver and power drill are two different animals. Power screwdrivers put out mere inches of lbs of torque compared to hundreds or even thousands of in lbs larger power drills are capable of. Let's be honest, its £1.96. With that said, I have used one like this a few times, but not for hard, heavy drilling. I use it more with my 1/4" hand held screwdriver. It's a novelty item and that's why its in the DIY section. https://www.amazon.co.uk/dp/B01H3HMPTG/?tag=atomicindustr-21
K
katiexoxo
eu
Would it work with the lowest torque setting of a Makita cordless drill? (for screwdriving, not drilling)
gdocktor3
Connecticut
:dunno: I guess it's a **** shoot. Will the drill even drive the screws in question in low? It's my best guess that this is designed to screw small sheet metal screws or peanut screws in/out of appliances, electrical items, stuff like that. I don't think it's designed to run 3" wood screws into studs or anything like that. I believe it is meant to install/remove screws that are in pre-drilled holes. That is what a screwdriver does. I mean, for the price, could you live with yourself if/when it fails? I'd feel better buying this one though http://www.sears.com/craftsman-9-in...5-K_Mm_R9pwo4vh7uOymcaAgeJ8P8HAQ&gclsrc=aw.ds
AnEv942
Central Coast Ca
Ive used in dremel (mototool) for remote use of accessories. They do work but as mentioned for running nuts onto threads, machine screws into chassis, light screwing into predrilled holes etc. With hex bits some light drilling. Agree- NOT going to run a 1/4"x2" wood screw into a 2x4. But the flex drives do come in handy-
the pop housing looks questionable?
UK https://www.amazon.co.uk/TRIXES-Silver-Flexible-Extension-rotation/dp/B01ITRNK8O/ref=pd_sbs_201_5?_encoding=UTF8&psc=1&refRID=TGMTT95EV72WZJ1WSB2J
