Flexible/round concrete form material
4EyedTurd
Texas
The goal: 8 roundish concrete tree edgings
What material could I use to for a circle frame with about a 30” ID and another circle that’s about 35”? I looked at MDF bender board but doesn’t seem flexible enough to make that curve. I picked up some flashing and even with stakes it’s way to flimsy. I gave up trying to find the curved scallop edge stones and decided I’d get the kids involved to help decorate the concrete. Making memories, ya know.
I’m not shooting for perfect, I’m going for maximum fun level. First one is done and daughter still has lots of glitter
plout99
Plastic 55 gallon drums, cut to the width you want and you can attach pieces together to make them larger in diameter. I made 32 inch concrete pucks this way for my pole barn posts.
Marctrees
TX/LA border - Toledo Bend
We used Lauan crosscut into 6-8" strips, face grain running w the 8" direction.
So, you have 48" pieces to work with...Lap and glue/ staple on bench night before to make circles larger than 14"
Stakes as needed to hold in place.
Check if soaking the Lauan will make it bendier w/o falling apart.
Lastly, whatever you did for the photo looks to me worked great.
Totally flat Galv steel flashing coil would work way better than Aluminum.
Feel the diff gauges w your hand at store.
If I did it again tommorow, and wanted the tighter radiuses in your photo, I would go w flat coil flashing, after feeling at store.
Excellent to involve the kids.
Marc
4EyedTurd
Texas
We all talked about it and decided they liked the silly/goofy shape, I’ll try the next one and as long as we don’t get it to thin on the sides we’ll rock and roll with it. Worst case I’m out 5$ worth of concrete.
nadogail
Coronado, CA
If My memory serves me right, Masonite is a brand name for the material generically refereed to as tempered hardboard.
I would think it would be suitable for the purpose.
Jackfre
N CA
I've done quite a lot of tight radius with the "1/4" tempered hardboard/masonite" material. Cut your plywood backing at the radius you need and wrap the tub around it. Support as necessary.
