garageman921381
Polyaspartic Floor, Still Smells on Day 5 - Normal?
Had a new polyaspartic 2-part flake floor installed in my attached garage last week by a local company who is very reputable and does about 500 of these installs per year (5-star ratings everywhere, installers and sales rep seemed really sharp). Slab for the garage is about 4 months old with no previous floor system on top, just a concrete sealer. Vendor did a good grind, put down the Flexmar base coat and let cure for a bit, added a few boxes of flake let cure for ~1.5 hours, and then did the Flexmar top coat. Whole house smelled that day but I'd say the smell went down by 50% by the evening. Garage has a front and back overhead door and both were open for the install (outside temp ~32 F). Doors kept ~2ft open for next 5 days except for one night where I cranked up the garage heaters to 70 to make sure I got a good cure. During the day, I tried to keep the doors open all the way for max airflow. Fast forward to today (5 days later), and when I close the garage doors the space still has a very strong smell (just like when the install was done).
Spec sheet for Flexmar says it can be installed in low temps and has a very short cure period. Sales rep says floor is fully cured at this point. Not really sure where the smell is coming from. Garage had no smell prior to install.
I knew it would have some smell and it would take some time, but am I being unrealistic that the smell would be gone after nearly a week? Anyone have thoughts/advice? Literature says that the smell isn't harmful (zero VOC and all) but I am sensitive to these things and it is bugging me. Something must be off gassing to make the smell (so I am also curious what chemical the smell actually is). Tempted to make the vendor grind it all off if this doesn't stop soon but I also don't want to be impatient.
All opinions welcome. Thanks in advance!
gM
gM
