bannerd
Howdy, been looking for a float switch that will cut power to a 120V pump running around 7amps. I have a small oil sump that is filled with oil for my waste oil furnace. What I would like see happen is when the tank is full the pump is off. When oil is used and the level decreases the float will fall causing the oil pump to kick on to deliver the oil.
Easy enough concept, anyone have a part number or url where I can find a switch like this? The oil is heated but it's only heated to about 80F so it's not hot enough to destroy a standard switch.
