Floating Shelves with Metal Dowel Rods
whitecarrera
So, I did something really cool today, and it was a completely original idea; doubly cool because it turned out so well. I'm not saying I'm the first to do it, but I didn't find anyone online who had done it this way. Normally I'd post this in my garage gallery, but wanted this to have its own thread so that it would be more searchable.
Anyway, we bought two live-edge oak pieces for floating shelves. The shelves are 2" thick and about 10" x 31". Each is 15-20 lbs, and I'm planning to store liquor bottles on them, so I needed the mounts to be strong but still completely invisible. Nothing I could find seemed sturdy enough, so I got creative. I bought 1/2" cold-rolled steel dowels from Lowes (two for $15 each),and decided to drill straight into the studs in order to use the steel bar as dowels.
This is what I started with. The wallboard is 1/2" mdf, so not strong enough to hold much.
I bought this tool at a woodworking shop, that helped me to drill straight holes. It's important that the bit had to be the same diameter from tip to shank, so that it would stay straight all the way.
First, I drilled holes through the wall board and 3 inches into the studs. I know the rods don't look level in this pic, but they are.
Here are all four metal dowels in position.
In the shelf boards, I drilled 1/2" holes 7 1/2" deep. This was the only real tricky part, because it ultimately comes down to your ability to drill a completely straight hole. It was a lot easier to tap the rods into the shelves first, and then into the wall second. I used a big rubber mallet to drive them all the way into position.
Here is the end result.
If you want to see my entire build, it's here:
Indianapolis - New 28X40 Garage /Pool House Build
whateg01
doo dah, kansas, usa
Nice looking shelves. Not original. Yes, done frequently. Lots of Internet examples. But nice looking job.
Shiftless
East Bay SFO
Nice solid looking shelves. I see your bourbon right up there next to the vermouth. Are you a Manhattan fan like I am? 🥃🥃
Shiftless
East Bay SFO
A bartender at the Awahnee Hotel in Yosemite park turned me on to using walnut bitters instead of the usual Angostura. Makes a difference!
W
whitecarrera
I skip the bitters but split the vermouth 50/50 between sweet and dry, usually with a rye.
tarbellb
Oregon
Nice work
This is a good trick for a straight forward install.
I typically like to put a lil angle on the rods to account for sag over time
BTL-A4
Santa Clarita
I'm impressed that you were able to drill the holes seven and a half inches deep and drill them straight.
karoc
Hemphill Tx
Thanks for sharing your technique, I have project like this coming in future for all my old soda bottles and old canisters
W
whitecarrera
Yes - drilling the deep holes was definitely the trickiest part. The little alignment tool I used really helped, but I think I could have made a piece to be even better. Even with all that, it still took some good whacks with a rubber mallet.
