Flood Light Tripping Breaker
Deadsquiggles
Chesapeake, VA
So I finally got around to running a flood light on the front of the garage. Got everything hooked up the way it’s supposed to be, power comes from the panel to a switch by the door, then runs from the switch to the light on the front of the building. If the switch is up, it trips the breaker, if the switch is down, no issues and the lights works normally. I think total draw if I were to use standard 60W bulbs would be 1A, but I’m using LEDs that are rated at 16W.
Its a Heath Zenith HZ-5411-WH-G and GE LED PAR38 bulbs. It’s on a 20A breaker and 14/2 wire. I can’t find anything from the manufacturer stating what breaker size to use.
Is this one of those weird things where the breaker being too big is the issue or is something else that I’ve possibly messed up at play?
I took a video but can’t seem to attach it.
Also, it’s not causing any other breakers to trip like the freezer or mini fridge. Not sure if that helps.
sparky 1971
Central Iowa
It's pretty hard to wire the fixture wrong but I've seen just about every way to install a switch wrong by DIY'rs. 14/2 from the panel to the switch. Pigtail the ground, connect it to the green screw on the switch. Wire nut the neutrals together (white) and shove them to the back of the box. Black from the panel to the top brass screw, black to the light on the bottom brass screw. Make sure there's nothing pinched or a staple too tight.
EDIT: I was in the process of posting this when the pictures went up. Lucky guess on my part.
The Cobbler
among other things , it looks like you have the neutrals tied to the switch, they should be just connected to each other with a connector . the black that goes to the lamp goes to the switched side of the switch
D
Deadsquiggles
Chesapeake, VA
So pig tail the grounds together with a single wire going to ground screw
White wires get wire nutted together and never to touch the switch
One black wire to each screw
Did I get that right?
sparky 1971
Central Iowa
You also should not have a 20A breaker on 14/2 wire. It should be a 15A.
Yes. I stopped reading after the first paragraph. Put it on a 15. Or change the wire to 12/2.
Norcal
I could not tell if there is a connector on the grounding conductors they cannot simply be twisted together, a splice cap, or a Greenie, are a couple of examples of what can be used, copper splice caps are my preference cheap, quick, & effective.
D
Deadsquiggles
Chesapeake, VA
There’s a wire nut on there holding the three wires together. It’s just a little difficult to see from where I pushed it into the box. They’re not just twisted together.
andrew61987
USA
I'm probably overcautious, but for how dirt cheap light switches are I'd consider tossing in a new one after closing a bunch of dead shorts as you no doubt have done with that one.
Wiz02
Southeastern PA
I appreciate all the help, guys. I definitely need to reread up on electrical or just stick to mechanical.
@Deadsquiggles, Glad to hear that you're going to do some reading on the subject. I'm not saying that you need to memorize the National Electric Code (NEC), but you do have to have basic electrical theory and have some real world knowledge of how the theory is implemented. Bad things can happen if you don't.
nadogail
Coronado, CA
When I saw both the white and black wire connected to a Single Pole, Single Throw switch I called out BINGO.
When the switch is in the on position the "Hot" Black wire is connected to the White "Neutral" creating a "Short Circuit".
D
Deadsquiggles
Chesapeake, VA
So I swapped the 20A breaker for a 15A and changed out the switch since it was only $5. Hopefully it should all be squared away. Thanks again, guys
yeah the contacts inside the switch gonna have some pitting... best to change it
D
Deadsquiggles
Chesapeake, VA
Did you get confused reading the Best Electrical Tape? thread?
You're supposed to wrap the tape around the device, not your finger!
But that's a fine tape job. :p
Yeah I tried to take the tip off my finger off with a Phillips head screw driver. And I appreciate the words on the tape job, I had to make enough makeshift bandages that I got a pretty good system for it now lol
