Flood Light Wiring in New Barn
jaw22w
indiana
I have my new barn all wired up and ready for spray foam installation. Now I want to add flood lights on each end of the building. Of course, the sub-panel is exactly in the middle of the 2 floods, and I want both floods to be on the same circuit. Is it code compliant to run a wire from the breaker to one flood, and then run another wire to the flood on the other end of the barn using both terminals in the breaker? That would save almost 100 feet of wire.
larry4406
Northern Virginia
Some breakers are rated for double tap while others are not.
How are you switching the flood lights? Or not and using photoeye?
If direct wire would it require a panel lockout? Or are lockouts only for 240V direct wire devices?
J
jaw22w
indiana
Yes, each flood has its own switch right next to the sub-panel.
It would be wired breaker to switch to flood on one end and breaker to switch to flood on the other end with both wires to the same breaker. I know I could add another breaker for the second flood, but don't see the necessity of a second breaker.
