Floor coating question
davo-55
My elderly (87 y.o.) dad wants to coat his garage floor before selling his house. I power washed the floor, then washed it with a concrete cleaner. There are still a few spots that turn water though. Will the cleaner /etcher take care of this so the epoxy sticks to the floor, or do you have to grind away the surface of the concrete so the epoxy will stick ? Any advice is welcome. House is about 30 years old . Floor looks new btw. Would muriatic acid be helpful? Thanks in advance for any advice.
gatchel
West of King of Prussia, PA
Are they grease or oil? Try a cleaner/degreaser first. If the floor was brand new you could probably just acid etch it. I would grind it.
I am exaggerating a bit but 95% of epoxying a floor is the prep. From my single project and what other threads I have read here, the epoxy and flakes are the easy part. If you don't prep right it won't adhere properly and you're asking for problems.
I wouldn't do this, but you always could just etch it, coat it and be done with it. It won't be your headache if at all. You might get bad Karma though. :evil:
Edger
Melbourne Australia
Etch it first with muriatic acid then test for water beading. If water beads in some spots where oil was you need to use a strong alkaline cleaner on those, wash thoroughly and test beading again. If OK coat and don't worry about it, if it is not 100% it will take a few months for anything to show up, more probably a couple of years. I doubt it will ever show problems which normally occur because of zero preparation.
