Toomanytools?
Thought I would post this it's mostly just a way to keep all the flooring options clear as to what is out there. I hope it's accurate, if not I'm sure the floor guys will correct me. There are some other coating options (staining and clear coat) but this gives you the main four I think. This was mostly for myself as I was getting too much info on what was what.
I have two spaces that I want to coat, one that is mainly vehicle storage with a section for metal work welding and grinding, which at this time I don’t do a lot. That total space is 2000 square feet, the other space is 1000 sqft which is a woodworking area, that floor I'm thinking epoxy.
For the vehicle space I think I basically want to protect from oil, gas spills and have a floor easy to sweep up. I’m a bit conflicted if I want some color to it or just a clear having the concrete show through. Don’t want to grind down to sand or agg type finish.
I have been looking at some products: Which fall into four categories, Acrylics, Polyurethanes, Epoxies and Penetrating Sealers.
1. Poyurea/Polyaspartic: Think SPGX and NOHR-S fall into this, thinner mil film than an epoxy, short pot life 10-25min, UV stable, has colors available. Looks to be a 2 coat system 1st being primer and color, 2nd being the clear coat. I figure $1.00/sqft cost.
2. Next would be a Polyurethane coating such “Rust Bullet” which is 70% solids goes down about 2-3 mils. No mixing A & B, 30 day pot life. Prep says no etch, no grind needed just clean then I read Polyurethane doesn’t bond well with concrete? So seems a grind would help that. UV stable better wear and abrasion resistance than epoxy. To get a thicker mil can do epoxy with a poly clear which gives you a UV stable finish. Site says about .85 cents /sqft but 2 coats required so don’t know if that has to be doubled.
3. Looking at Epoxy finishes I see 100% solids and High solids about 93%, then on down to 50-70% solids. Which I get the epoxy finishes and the plastic flake or quartz and a clear coat. Seems the system is: Primer, color epoxy, chips if you want then a clear, with polyurethane being better than an Epoxy clear because being more UV stable. Seems to be about $1.40-1.50/sqft
4. The last system being a sealer, using a densifier and a sealer which basically is a silicon. It soaks in and doesn’t build a film. Protects from fluids but not so much from dropping something like an epoxy.
Seems most of us on GJ are DIY's, I know I don't want to spent much more than $1 - $1.50/sqft on the floor.
One of the flooring guys was thinking of a short video on the systems and a quick how to and why on each hopefully something gets out there.
Not suggesting this post but it seems the flooring section needs a "Sticky" on the flooring options. I know the same basic questions get asked daily. "I have a new floor what do I use, why and how much does it cost"?
Hopefully this might help it's not the "word" just my late night pondering.
Jeff
Jeff
