floor covering....for metal fab
pennsylvaniaboy
Ok guys.....I bought a new house with garage. The floor has some issues that I and slowly addressing like waviness and and low/high spots. I used some concrete patch and it's starting to become "level". I would like to do an epoxy type covering so that it looks uniform and nice, as I painted the rest of the garage which looks great. Here is the big question:
I do metal fab work as a hobby. Mostly welding and abrasive cutting, although i do break out the torch and plasma when needed. Will the epoxy type coatings hold up to small spals and sparks, etc landing on them? I am not planning on doing major torch cutting without throwing a piece of plywood, or scrap sheetmetal under the drop area. But as anyone who has cut with these tools knows, they shower sparks/spals that don't exactly fall straight down.
I am looking at rust bullet as it seems to have a great reputation and my floor is less than perfect.
benwah
Lakewood, Colorado
Molten steel will definitely damage topical coatings. You're on the right path dropping plywood or sheet metal, but splatter marks can still occur.
P
pennsylvaniaboy
I realize that no flooring with withstand it entirely, but the floor is pretty grodie. I need to do some coating. Again I will lay down hardi board or sheetmetal when doing intense work, but I will was a coating that will with stand mild fab work without getting badly damaged. I have read a lot of those threads and most suggest densifier, but my floor is 2 different appearances since i have done patching, etc. I would like to hide that. Perhaps I would be better off using a cheaper solution that can be repaired and recoated easier?
Garage Flooring
Grand Junction, CO
Agreed, low cost acrylic with tint.
If your going this route with the knowledge its going to get messed up (as would epoxy, rust bullet, etc) I would just add go solvent based, order extra and a simple recoat procedure.
Your dealing with the lessor of several evils.
One thing I would have to consider here is grinding the floor, good primer and heavy flake followed by a good top coat. Sounds like slag is the exception as opposed to the rule so use a weld blanket or piece of plywood when you do.
The downside to that, is many acrylics can be repaired with almost no prep. That is not the case for epoxy.
P
pennsylvaniaboy
Our HD6600-MMA is the best of acrylics. You won't sacrifice much when using it.
Two roller coats.
http://www.legacyindustrial.net/products/concrete-sealers/hd6600-mma-concrete-sealer.html
My only concern about a sealer is that my floor is not smooth. Its a fairly pitted and abused floor, im guessing circa to the house (1920). The patches were put down after etching with muriatic acid, although I have a spot or 2 that needs to be fixed because they lifted.
As you said heavy slag will be dealt with by protecting the floor appropriately. I just want something that will hold up to mild welding spatter, grinding sparks, and cut-off wheel shower.
