boseefus402
- Joined
- Dec 30, 2006
- Messages
- 183
I have a 2 car garage. The concrete was saw cut in the middle lengthwise and width wise so basically it is 4 big squares.
The builder sloped the floor all to the middle of the garage, as if a floor drain should be there, but there is no floor drain! I get this slimey pool of water there all summer from the A/C dripping when the cars park, and then all winter from the snow melting out of the wheel wells.
I don't really have the means to core drill through the concrete and put in a 3" drain hole, even if that is the right solution. Should I drill a 1/4" weep hole down in the center to let it escape to under the pad? Is that a good idea, or will it allow too much moisture up through the pad? I'm open to suggestions.
