Floor drain
Chuckie63
What type of floor drains are you guys installing in your garages. Are they cast or pvc.
Dale1962
central illinois
just my 2 cents. if I would put a drain in a shop, I would just run it to a sump. not outside. that way IF something gets in the drain like oil, solvents, and the like you can pump it into a container for disposal. if its just water, put a sump pump in it and pump it outside, that way the EPA does not get after you
chadman
Wakeman, OH
Mine are about 9" square and made from some type of plastic or PVC. They tie into the underground piping for my downspouts and runoff into the creek.
denis4x4
Durango CO
Mine go across the entry with removable grates and dump into a sump. I have a big squeegee to push the snow melt into the grates
Good suggestion ! Most cities will make you jump through a lot of hoops to hook up a drain to a municipal sewer or even run it to a drywell. If you plan on doing car/ATV washing make sure you size the sump appropriately (10 gallons ? 20?)
coljar
Belpre, Ohio
Brass square commercial cover with a cast base. I should have put two.
redrunner
NW Iowa
I made a custom stainless steel drain with a oil water separator and sediment trap as well. I hooked it up to the city drain. I agree the process was a real pain the behind. In the long run it will be great.
bigpokie
No matter which kind you go with by an extra or two. So if/when I breaks you can find a replacement. I work at a plumbing counter and hear that problem week after week. You can also look into traffic rated floor drains too. May be a little overkill but they hold up to town motors driving over them.
