Getting ready to lay down Armorclad / Armorpoxy 100% solids 2 part epoxy soon. After looking for floor grinder equipment - I am getting frustrated at the escalating costs. However I want to do it right.
My floor is 500 sq ft and currently has an @12 year old paint job on it - it is not thick, not sure what kind of product was previously used...likely a cheapo product. Otherwise, the floor is in great shape - no high/low spots - just a few shallow divots that I can prep and patch prior to new epoxy coating. Anyway, to prep the floor, I'd prefer to remove the old paint job and grind enough to prep for the new epoxy.
During my research, I came to the conclusion that the existing topcoat of paint should be stripped (using the grinder mfg appropriate stripping attachment) prior to grinding with stones or diamond attachment. Bottom line, when drops of water are thrown on the floor, they should be absorbed - not laying on top. If laying on top - you need to grind more.
Option #1 - get it done in a day
Rent a machine (Edco or Stow - only electric are available near me) $100. Rent Strip insert ($125), Rent Diamond insert ($125). The Stow rental is cheaper - but does not offer the diamond or strip inserts - therefore I am taking a chance to try to do it all with stones only...not sure how fast the stones would wear out.
Would still need to get the corners, so say another $100 to rent an angle grinder for a day.
$450
Option #2 - Grind at my leisure
Buy a 7" angle grinder (say $150 - however Harbor Freight has a $45 unit) - I cannot find a variable speed unit with a vacuum attachment - not sure if the 8,000 rpm or whatever would do more damage.
Diamond cup wheel ($95) and some kind of dust shroud attachment (that seem to get poor reviews for effectiveness) $30. Could likely get it done over 3-5 days.
@$200-$300
your thoughts?
$450
@$200-$300
your thoughts?
