We'll to start I will fill you in with what I have going in. I built a shop this summer it is 36x48 with 12 ft side walls and vaulted scissor rafters, I beleive the center of the ceiling is about 16 ft. It is all 2x6 construction and will have roll in r-19 in the walls and at least r-45 blow in in the ceiling. I used icf forms for the pad, I put down 2" insulation with 8 loops that are 220'-240' long then 2" of sand covered by a 5" slab. The tubing is about 6" apart around the perimeter and they gradually become about 12" apart in the center. I have two overhead doors one is 10'x10' and one 10'x12', they are insulated doors rated at r18.5. It also has two 36" walk in doors and four decent 24"x36" sliding windows( I know I should have got crank outs).
I am in the process of wiring it so I can get it insulated (it is starting to get pretty cold here in North Dakota). So I've been reading in here and looking at other sites to find which electric boiler I need so I know what size of wire to run to my location from what I have found I need about 75000btu's. This is fine and I thought I had it all figured out and needed to run 2 runs of 6-2 wire for two 60 amp breakers. Right??
Here is where I get thrown for a loop. My neighbor had a shop built this last year also his is 34x52 and has one 10x16' overhead door rather than two smaller ones otherwise it is built identical to mine. The reason I know they are built the same is the contractor who built his is a friend of mine and helped me with mine.(and I helped him a little with the neighbors). Anyway he went to the local electric coop and purchased what they recommended for this shop and had them install it. They put in a 10kw, 34000 btu electo-boiler. I thought right away that I was glad I did some research and mine was going to work better and he was going to want to upgrade but, his works great!! He keeps it set on 60, it's very comfortable, it's not hardly ever running even the last few nights when it's been down around zero! I was going to wait and see what his elec bill is going to be but u kinda wat to get mine wired. So is his too small or was I thinking too big? Any help would be appreciated!
One more question if someone knows, do I need to run a 20 amp circuit for the circulation pump or can you power them off of the boiler?
Thanks for any input!!!!
