I thought about making one before I found that harbor freight sold them. Still don't have one though. My reason for thinking about it was for a car that didn't really have a good place in the front to jack from. If I need more height, I just use a block of wood on the jack saddle.Anybody use one?
They just look like they might be handy to get the front or the rear of the vehicle raised up quicker
No, in my experience the vehicles that lack a good center jack point also don't really have enough ground clearance to position a crossbeam and a floor jack under it to lift from center.Anybody use one?
The ones I recall had a 1" shaft that dropped in in place of the saddle. Maybe newer jacks have the saddle bolted for safety
This is my dilemma. I like the idea of it, but lack any cars that it is practically useful for.No, in my experience the vehicles that lack a good center jack point also don't really have enough ground clearance to position a crossbeam and a floor jack under it to lift from center.
Mine is certainly not newer (at least 5-10 years old) and the saddle pin is a threaded piece that uses a large hex key to secure/remove.New ones are definitely bolted. They had one set up on a jack in the store, it's a large allen bolt that goes downward into the jack.
Same way with the saddles, if you pull the saddle pad off you can see the bolt.
Tried to pull each one upwards/off, no dice.
I just pop off the saddle and bolt on the cross beam when I need it. It's just a bolt with a hex socket head. But you have to be careful to not lose one. The cross beam takes a longer shank bolt than the standard saddle.I just went there today to buy one, but I found out the saddle on the Daytona jack bolts to the jack, so to use this you'd have to unbolt the saddle, bolt this on, then vice versa to go back to the saddle.
If I had two jacks so one could permanently have the cross beam I'd probably get it.
