Anybody here knows their way around a floor jack? About 2 weeks ago I found it on the floor leaking and thought it needs seals replaced. Because of lost oil, I had a hard time pushing the lift up but once I did it stayed up no problem. Now I'm pretty sure I just stored it sitting vertically against the wall with the universal joint/valve open and that's why it was leaking, so it might not be anything wrong with it after all, just an oil top up.
Anyway, before I thought about that I did proceed to take the back piston spring out, pushed the piston in a few times and now I can't seem to pull the piston out no matter what I do. I turns around quite easily if I use a pair of pliers though.
I can't take off the square drive piece either, I tried with a 26mm wrench and it almost broke my back. Next thing is to use a cheater bar but I'll have to go buy a cheap wrench for that and cut it's ring head off.
Anybody knows the inner workings of that jack, why would the piston get stuck like that?
Many thanks
Many thanks
