Floor jack ( Hein Werner WS 1 1/2 ton)
steven49
how do you put oil into this jack. Do you stand it on end and pour oil in until it is full or do you leave set on its wheels and pour oil in until it runs out the hole. I need to know the correct method of installing the oil.
Please Help
Thank You
steven49
Hiball
Missery
8 Ounces (Well 7 3/4 per the manual) of OIL from completely Empty to Full, They are difficult to fill when assembled as the Fill Hole not only has to let OIL in, It has to allow Air to exit. If you can get it up on End, It will slowly fill or you can remove the release to give the Air another path to displace.
SmanPlymouth
Hello, HiBall,
Just picked up what appears to be a CS or OS 1 1/4 ton Hein-Werner. Before I can conclude need for rebuild kit, which you indicate you may carry, I need to know how to bleed, where to open to bleed, and maybe some other instruction. Been looking it over and doesn't seem to be too difficult to get into but like having a manual or whatever to go to. Any help is appreciated. Steve Foley Plymouth MA
