floor jack identity
tominos
hi guys,
i got this ******** of craigslist, though it doesn't have any tags that i can read on it. the guy told me its a walker 2 ton but i'm not sure. anyone have any idea what it is?
also, theres a plug on top of the (fill hole i believe) and its missing/the wrong size and leaks oil out of it. can i just cap it with any rubber plug that i can find?
pop pop
Virginia
Doesn't appear to be any Walker I've seen. Can't see the hydraulics. That would tell for sure. Hiball will be by after a while. He's the expert for sure. Closest Walker that I know of would be the 93633 that is similar, but I don't beleive that is what you have. Someone posted pictures of a 33 here lately. Yours might be an import.
Hiball
Missery
Import.. And some of them had a screw in reservoir plug, probably has too much oil in the reservoir and its displacing when lowered ( i would check this first) Maybe the plug seal is bad? Replace as needed if the correct oil level doesn't correct the issue, proper oil level should be just above the inner cylinder when peering thru the hole or aprox 5/16" below the top.
T
tominos
you guys are right. looks exactly like my performance tool jack. darn.
well thanks guys.
