Hiball, that makes sense to me, but today I really have a bit of the curious. Out of sheer boredom and an inquisitive mind, i went outside to the jack, removed the upper screw from the Overload Galley and removed the excess oil from atop the rubber plug. I turned the handle to open the release valve and proceeded to pump away. Lo and behold if fluid didn't rise above the rubber plug again. What possible pressure pushed the fluid up like that? Smoke coming out of my ears. Houston, we have a problem. I decided to bleed it again so with the release valve open, the cradle down and the reservoid topped off, I began pumping. Fluid would overflow from the fill hole every now and then but the cradle lifted to its highest point. I put the fill hole plug back in, thinking the reservoir might need it for proper operation and it danced around as I pumped. I held it down with my finger and when released it spit a lot of air at me. It did this twice and then stopped. I topped off the reservoir once again and pumped a few more times without any oil appearing above the rubber plug atop the Overload Galley. Put the top screw back in, closed the release valve and raised the cradle all the way up. The cradle lowered itself very, very slowly. I have nobody around to remove the jack from my work table so I do not know if it will lift a load. Maybe one of my 3 sons will stop by one day and help me or I will just have to wait for my back to get better. Hope this book allows you enough info to give me some more good ideas as to what is going on with this jack. Thanks, Alton.
