Floor jack???
tommyloan
Hello… I’ve been an “at home DIYer” for 20+ years and expect another 20+ years. I typically use my floorjack probably 3 or 4 times a year, so heavy use is NOT the “need”, but instead, it’s the longevity that I’m after- seals that will not harden or fail because the jack sits 99% of the time, or because it’s 10 yrs old.
I’m thinking I need a “low profile” jack since I need to lift both lowered cars and SUV’s. A Chevy Tahoe is just under 6,000 pounds and since I would only be lifting one end at a time, I think a 2 ton (4,000 LB) jack should be fine.
From my 6 hours of research, the Omega Lift floorjack #29027 is a 2 1/2 ton and all the specs look great: good min and max heights, not overly large (long), not too heavy, etc, but in the end, I think it’s made in Taiwan, and I haven’t seen anything about what kind of seals it has.
Again, not needing the most super duty, highest-use jack (I’m not working in a shop using it all day, every day) I just want a quality jack that will last a minimum 10+ years, and from the research that I’ve done, probably something that uses U-cup seals, although I know there are some quality jacks that (when designed well) still use O-ring seals.
A lot of people rave about the HF Daytona Super Duty, but it sounds like it’s built for heavy daily use, while for me, I need something that will see little use, but needs to have internals that will stand the test of time from sitting around.
Which brand and model would you recommend with the following needs: low profile, decent max lift height, 2 to 3 ton capacity, wide front wheels (not wanting a jack with a narrow single-roller, “needle roller” front wheel), not overly long (like some 36” ones) and somewhere in the $250 to $600 price range?
Thanks in advance 🙏
ajchien
Los Angeles, stuck on the 60 freeway.
I had thought that Shinn Fu made their brand names for different markets. Hein Werner is the made in USA or assembled in USA products. Omega as their industrial brand, and blackhawk/pro-lift are their home user/auto shop brands.
mikedodge
I've never had problems with the cheapest jacks I can find. The newest is 6 years old the oldest is over 20.
I have a couple long frame jacks for heavier stuff or bigger vehicles.
Do a quick look through the forum, there are a lot of posts around about jacks with just as many different recommendations.
Leaflessshadetree
Don't ask.
I have an 2 ton Arcan low profile jack that I've been happy with. Min and max heights were better than others I considered. I also looked at one from AC jacks, I couldn't find anyone that had it in stock and price was going to be quite a bit more (2x-3x) than I paid for the Arcan
Tynee
In the Heart of the Bluegrass
My use case is very similar to yours. I've found the 3-ton low profile Pittsburg from HF to fit my needs pretty well. I've had it 5-ish years now. Just used it last weekend with absolutely no difference that the last time I used it several weeks ago.
Looks like they no longer sell it under the Pittsburg brand, but I suspect this Daytona is the same jack:
sdowney717
Get a used jack cheap or free.
I have 5 floor jacks and never bought a single one. 2 are big, 3 are smaller and I gave away a blue Michelin that needed a handle.
I picked them up from neighbors who threw them away. All of them work ok. If they are missing a major part, I can understand why people toss them out. Can not imagine buying one for a few hundred dollars. Lately though things getting thrown away are not so good anymore, maybe people are poorer. Frequently they leak oil cause all they need is an O-ring somewhere.
sdowney717
3,000 pound lift for $99. If you do not need a 3 ton jack why pay for one that is close to $200.
Figure out what you will be using it for and buy appropriately.
Pretty sure this jack could lift any wheel on my 2005 Cummins Diesel Dually 4x4 truck, whole truck is 8,000 pounds, but each wheel far below that.
And you know jacks do quit working. They do, then the extra money spent is totally wasted unless you can repair it.
Tynee
Because I liked the extra 6" lift height. I've got at least that much extra height myself when I'm laying down.
Also, if I'm buying a tool to use for the next decade, I'll spend a little extra to be sure I've got a tool that will handle anything I might get into.
Third, I like being able to pick up either end or either side of a vehicle, not just one corner at a time. It's safer than lifting a corner and setting that on a jack stand while I go around and pick up the other corner.
Define "need." You could theoretically get by with the scissor jack that came with your truck, so why would you buy a jack at all, or even pick one up on the curb and spend the money and effort on a seal kit?
The OP asked for recommendations, I've made mine. He can choose to do with my opinion and yours what he likes.
sdowney717
That 99$ jack has tons of good reviews.
If I was using it to lift my truck from the frame, I would use a big block of wood on top the saddle. My Ram 3500 sits up pretty high. It could however lift the front axle ok by itself.
sdowney717
It is definitely not safer to lift an entire axle, 2 wheels off the ground at the same time. Vehicle could more easily shift around. If 3 tires are still on the ground, it is less likely to move on you. Better to lift one tire at a time, place a jack stand, then do the next wheel.
PatDubois
St-Jerome
Thanks in advance 🙏
Hello Tommy! If it's longevity you seek, take a look at our DK20Q model. It should hit your sweet spot. Here's a link to our website: https://www.achydraulic.com/us/products/hydraulic-jacks/dk20q-3601500/
Lamakocklee
Hi PatDubois,
Not to hijack your response to Tommy.... but are you a representative for AC Hydraulic? If so, I just wanted to give you some feedback regarding the DK20Q packaging. If not.. disregard my rant :)
I recently purchased 2 of these for my shop. I'll admit, these are very nice jacks. Different design than the typical Taiwanese units. The jack is great, however the packaging leave a lot to be desired. The first one I purchased was delivered without a hitch. The second one came damaged due to the lack of support in the packaging. The replacement for that unit was even worse. The handle tube was scratching the jack body so bad, it rubbed off the powder coat on both the handle tube and the jack body. It appears the packaging does not support the jack well enough if the package is turned upside down allowing the jack itself to rub on the handle tube. Also, it wouldn't hurt to have the plastic D packaged in a separate box to prevent damage to the handle itself as well as one of the replacements sustained damage to that part as well.
In case anybody is curios Amazon is great about sending replacements. Not sure about getting replacements if purchasing thru other channels. Attach is a picture of non damaged package for reference.
Sumboodie
AK
3 ton Daytona. $100 from Costco around 2009.
Only time it's struggled a bit was lifting dump trucks and semi trucks.
Jtels85
I'm also looking for a new floor jack. I want a 3 ton, low profile.
I've looked at everything from Pittsburgh, Daytona, O'Reilly's, Duralast, TCE on Amazon. They're all made in China and reviews seem to be all over the place. I really can't decide which option is best.
MovingAlong
Which brand and model would you recommend ...
Been using a Pittsburg 2.5 ton, low profile, rapid pump for at least 10 years. Forget what I paid for it, but still works just fine. When working on a Miata, it was helpful to pull up onto a flat piece of 2x material first to clear the air dam in front. But those cars are really low.
While my model was discontinued and made of steel, I'd be tempted to go with the aluminum model for $220 - "if" mine ever gives me any trouble...
But you may like the controls of another brand, the styling or even just the color. Lot's of jacks meet your requirements, you're going to have to pick one based on more emotional criteria.
Might check out this YouTube review from Project Farm on floor jacks too...
PatDubois
St-Jerome
Hi PatDubois,
Hello! Sorry for the delayed response, I[m not on here often... To answer your question: YES, I work for AC Hydraulic. Your feedback on packaging is dully noted. One of the issues is, the boxes go through many hands before reaching final destination when sold through a channel such as Amazon. I appreciated your message and thank you for buying our products!
5-cylinder
For others in the same boat - another vote for AC Hydraulics, I recently got one and I like it. Top contender if you are also looking for a jack not made in China or from Chinese parts kit as far as I could tell (could be wrong). Your truly made in USA alternatives would be Gray ($1.5K), Shop Boss ($2K) or Argo ($900) if racing jack is what you want. There is Japanese Zinko ($400) but with Chinese body/parts? Compac has a plant in China, so not sure what you get - one made in Denmark or China, and where innards are made.
I am happy with AC Hydraulics DK20HLQ ($800+), got it from Pelican Parts, they have good customer service. Low profile (3"), 2 Tons, works well both on cars and heavy SUV, lifts scary high while being super stable. Quick pedal is awesome, it has bottom plate protecting cylinder (previous Chinese Michelin jack did not - so it rusted/leaked where cylinder hit concrete making it non-fixable). AC has gentle release (not totally controlled but amazing vs Chinese jack just dropping the load). Rubber rings on jack wheels is super nice (no jack rattling as it rolls). Handle is shorter than usual - which is good as you need little space to work it but lifting heavy suv might require some effort. 37" long so better have space for it.
@PatDubois - I had same experience as @Lamakocklee - though this time package came directly from AC Hydraulics warehouse in US - this was beyond ridiculous really - box was too small for a jack with part of it busting through the box, heavy metal pieces (jack saddle, handle, etc.) were just loose in a box with saddle being solid piece of metal doing a good job damaging all the paint and scratching up plastic handle part so I first thought I was sent a used jack from some repair shop. Not cool for $800+ jack. BTW this looks like a common experience if you search enthusiast forums.
ecotec
I have had the older grey version of the low profile long pattern 3 ton from Harbor Freight for around fifteen years. It is still working great.
pbon
Everyone seems to like the AC hydraulics jack but it is a lot more than most of the other options. That is what I would choose if cost was not a concern. I bought the Arcan low profile extra long reach 2 ton steel jack for $160 in 2022 when someone here posted an Amazon link. It is $300 now, but is an option to consider.
ctandc72
VA
I have the Pittsburg low profile 12 years now - it works fine,
I have the Pittsburgh low pro. It's at LEAST 20 years old. Still works fine. I recently bought the low profile / high reach that was on sale for $160 ($100 off) - I wanted the higher reach and the fact it's longer.
pbon
I had an aluminum floor jack twist and drop a car I was working on. I got out from under the vehicle just as it crashed to the ground.
I'll never use or recommend an aluminum floor jack.
I have experienced that but only when I did not have the jack at a perpendicular angle to the car or on a surface on which it could roll slightly in or out as the car was raised or lowered. I have never had a jack release unexpectedly and drop but have read reports of it happening. I have had 4 of the little HF 1.5 ton aluminum jacks over the last 15-20 years and still have 3. Tossed one because someone left it outside all winter and it corroded.
Have used them hundreds of times but do watch them carefully in terms of rolling and angle issues. I never rely solely on a jack when going under a car though I will rely solely on one or 2 when swapping wheels.
Definitely the bigger base and stronger construction of a 2 or 3 ton steel jack makes it more stable than a little 1.5 ton aluminum jack.
JuncleJohn
Omaha, Nebraska
I am on my 2nd Yellow Jacket 3 ton from Northern Tool. The 1st one leaked after a year or so. The 2nd one I’ve had for at least 5 years. So far so good.
It’s not a small light weight jack, but works well for me.
John
Steel_Rain
This one is also USA made, but is very expensive when not on sale ($1600):
Shows one left in stock, so you better get it now if you want it.
More details:
pbon
It is only a 1 ton, but that will lift half of a lot of cars and most track cars.
pbon
On the issue of placing the jack so it can move slightly or roll most easily as it is being used to raise or lower the car and from a stability point of view, is it best to have it perpendicular to the car, at a 45 degree angle or closer to parallel with the car? I think this is usually how problems occur. The jack does not move slightly and instead has forces on it that want to tweak it a bit and aluminum is weaker. I have watched this happen.
rooster59
Land of the Pines
If you have an Amazon account, prime w/free returns, there are a lot of floor jack seal kits available. With a caliper and a little luck you can find seals. No fit -> return. eBay has seal kits also.
Bought a HF Daytona Superduty, couldn’t be happier, it’s a beast. Orange is the more bestest color. One trick, drive a low clearance car up on 2 pieces of 2x12, leading edge cut at a 45. Gives you extra clearance to insert the jack. I always use jackstands if I can, trans in park + parking brake, wheel chocks all around, flat concrete.
jrsavoie
North east Illinois
I wanna 5 ton
