Floor Jacks on Pebbled Driveways?
ket-tek
I used to use sheet of plywood on my old asphalt drive when I'd use the jack on it, mostly to keep the jack wheels from making indentions in the drive.. It worked fine..
m.james
Plywood might stand up possible look into adding stone to you pebbled driveway.
Ford12508
Middletown NJ
Why not get a thick sled, like 1/4" of steel, and attach a rope to the front. drag it over the pebbles like the skids on snow blowers are made for.
nissan_crawler
Wichita, KS
When I raced dirt rack, I bought a cheap floor jack, took the wheels off, and welded a steel plate across the entire bottom of the jack. No worries on what surface it was used on then.
