The reason I was asking is that by the time you buy the wood, and I think you'd need a pretty serious vapor barrier (else wood will rot, mold issues etc.), and the materials and effort to hold the joists... it's not going to be cheap going that route either. For a 16 foot width, and a bunch of buddies, I think you'd be able to finish the concrete yourself to save $$.
In any case, what I'd do if determined to go the route you're mentioning would be to basically build a deck using concrete tubular forms placed at proper distances. I'd want to seal moisture and critters out really well before putting the subfloor on.
edit: though not nearly as stable, there are also pre-cast concrete blocks that are formed to accept 2 by material or 4 by material. I believe they're used for sheds frequently. With these, in my opinion, you'd still want it sitting on a level, compacted gravel base. But, I'd be wary of this solution because for as big of a space that you're mentioning, and for as much effort as you'll be putting in, it'd be a bummer to have it not last as well as you'd want.
