Re: Flor model router tables
Still no clue as to what type projects you're into, but if it includes a complete kitchen cabinet re-do, here's my version - as you can see, I also like Jessum products - the 2 non-cast iron tables are Rockler stands/mobile bases (possibly tops, if not Jessum) - the cast iron is an old HF offering, with a cobbled cabinet carcase on its side with Woodcraft's casters.
Cast iron has a 3 hp Freud (NLA), mainly for raised panel cutters - other two have DeWalt 718's IIRC. Idea being to use stile cutter in one, rail cutter in second, and panel cutter in the cast iron one. No lift on the cast iron, couldn't find one to fit. Height is adjusted on the Freud router, takes longer than I'd prefer. Other two have Jessum lifts, too long ago to remember a model (if it's even still available)
In the middle pic, the table on the right has an added fence control; zoom in behind the fence - the piece of micarta lets me first set up the fence for MAX cut and set the micarta against the fence - then I can use shims between that final stop and the fence to "sneak up on" things like molding cuts. Last "shim" being a thin 1/32" cardboard, leaves a surface close to sandpaper when it's removed for final pass.
Takes a bit to get all 3 set up, but worth it to me for a full cabinet job - in that mode, NOTHING gets re-adjusted til the job is COMPLETELY finished - for "incidental" things during that time, I have another DeWalt 3-base kit and a couple other routers... Steve
