Floor prep & flattening for laminiate flooring
EW57
Southeast Iowa
Greetings, I've got a loft/mezzanine that I'm interested in putting down some laminate wood flooring & I've decided not to include the foam underlayment as I'm not concerned about the noise & could do without the additional cost.
Overall the floor is reasonably flat, roughly 1/16" over 8', but I have a few plywood subfloor panels that don't match up perfectly at the seams. I figure if there are high spots I can take them down quickly with a belt sander, but I'm looking for some suggestions on filling the low spots.
Is there a wood subfloor equivalent to self leveling compound that would typically be used with concrete?
Thanks!
James-W
Southeastern Wisconsin
I am not aware of a self leveling compound specifically for wood floors, but I suspect if there is one and you were to cover the whole floor with it, it would cost as much as, if not more than, the foam under-layment.
kwfloors
In the great NW
You won't have a warranty with your laminate if you don't put foam in. That floor is pretty flat with your calculations, sand the joints, buy the foam and install the floor.
rsanter
visalia ca
I have used 30lb roofing felt under laminate with no troubles. I would not install with nothing unless you plan to glue it down
Bob
E
EW57
Southeast Iowa
Thanks for the replies guys! I should have clarified that the low spots (roughly two dozen or so) I'm concerned about are relatively small, as in I could cover one with my hand & I'd guess it'd take less 6oz or so worth of leveler to flatten each one. I thought if the low spots weren't remedied that you'd potentially feel them as you walked across the floor.
I've researched the manufacturers "warranty" & it seems those that have had issues & filed claims have had the manufacturer scrutinize the install until something was found to void the warranty. The guarantee/warranty scene from "Tommy Boy" was a lot more funny before I realized how accurate it was.
Rsanter, out of curiosity, what was the benefit of the roofing felt?
JakeKohl
Greenville, SC
When I was looking at leveling compounds a few months ago, there were instructions for using it on wood sub floors - that surprised me...so you could use it here too.
