FLOOR protection
redhead2
Southeast ohio
:dunno:I am installing a wood stove In my work shop, which has a wood floor in it. My question is, would a sheet of 1/4in. thick deck plate by itself be ok to set stove on it? Plate is 4'x5'.
Was going to place cement board then floor tile, then plate down, but thought it would stick up to high.
People that have installed wood stove on wood floor how have you done it?
THANKS for answers and thoughts before you post them. AGAIN THANKS
rburke65
Canfield, Ohio
Welcome to The Garage Journal! No help onthewood burner per say, but I do know thatformyfreestanding fire pit that sat on my wooden deck thdeck boards were REAL hot after an hour of burn time. I placed a sheet of SSteel under it about the same size as the fire pit and it made a real difference in the temperature of the wood.
Bondo
Greenfield, Maine
Ayuh,.... Ya don't have to go overboard,.... A sheet of tin will do the job,...
Bigger is usually better size wise,...
Jackfre
N CA
NO, you cannot. Well, you can. It is your place, but should it burn down, your insurance company will enjoy not paying the claim. You need an R value of .8 total on your hearth. 1/2" wonder board is .39, so a double thickness and the steel cap will get it for you. Actually, the appliance manuf should be calling out the R value for the hearth. Check your manual.
I'm installing a woodstove in the house and am going to make my hearth as listed above. One inch of wonder board and the cap will be 1/4" plate. I'm going with the plate to avoid having to repair the hearth. If I do it with tile or some thin slate or stone if history is any guide, I will break it. When I need to make fat piece of wood thinner and it is next to the stove I will split it there and not have to worry about breaking the plate. I'll clean it and repaint every spring if necessary, but paint is easier than tile. I am also fabricating a lower heat shield for my Vermont Castings Encore stove.
During the houses re-model I tore down the old stone fireplace. It had a fire brick hearth on top of concrete. I was shocked t see how charred the wood framing below the fireplace was. Was it only one fire or 100 from igniting. With Pyralysis the more you heat wood the lower its kindling temperature becomes. You create charcoal and one day it goes off.
walrus
Maine
You need some kind of hearth and they need some insulation in them. Placing tin or any metal directly on the floor will help protect from hot coals that might spill out but will just transfer heat to floor so that isn't what you want
Highbeam
Mt Rainier foothills, WA
Guys, quit guessing. Every modern stove is different, some require a specific r-value from the hearth and some only require ember protection. If you are using a barrel or some other unlisted stove then the nfpa regs must be followed. Same with the size of the hearth pad, each stove is different.
Op didn't specify the stove. Rtfm.
