floor seating ?
nu guy ky
Any Ideals On how to help this.. I thought maybe when it is nice and hot
maybe to do a few coats of sealer ?? any ideals thanks Dave
cadaver
high on a hill
i thought you meant floor sealing. so yeah, nice and hot and several coats. don't know if it'll help the sweating though. Maybe a dehumidifier?
PAToyota
South Central Pennsylvania, USA
It is IDEAS too, by the way... :D
Depending on what is causing it to sweat, sealing it will cause more of a problem. My epoxy coated floor sweats terribly when the floor is cold and the air is warm and humid - a problem solved by turning up the heat in the radiant floor a bit.
SC-Eric
Spartanburg, SC
I'm going to guess that your floor is actually sweating less with your coating and that you are just noticing it more because it won't soak into the concrete.
A thin coating will only give slight thermal insulation of the slab but since the slab is sealed the moisture doesn't have anywhere to go except to sit on top of the coating until it evaporates. Theoretically, the only way to stop sweating is to apply a thick enough coating (that is a poor thermal conductor) that helps to insulate the temperature difference between the slab and the air. We have never had anyone tell us that sweating occurs after applying our products. HOWEVER, we are just barely stepping out into the residential market where products are applied pretty thin. One thing our coatings have going for them is that even our lowest technology product (LiquaTile 1184) is a semi-ceramic. I would guess that a 60-mil (1/16th inch) coat would provide enough insulation to stop the sweating.
At some point... someone on here will try it and then we'll all know for sure! :headscrat
