Floor Standing Hydralic Press
PopPops
CT
I'm planning on replacing the bushings on the front of my car and making plans to get a hydraulic press suitable for the bushing and a bearing job I may take on.
I'm not sure what size I should get, 10, 20 or 30 ton.
It's easy to get one that would be over kill and I don't want one that is simply to small.
Any of you guys have experience with these presses? What would you suggest?
motofool33
Currently North of Houston
20 minimum car suspension bushings can be a real bear.
Swag has some nice upgrades for a HF 20 ton, personally I'm going for a 50-100 just so I'm not always at the limit of the press.
You can also do the air over hydraulic upgrade.
Sent from my SAMSUNG-SM-G900A using Tapatalk
JohnnyK8
Illinois
I got a 12 ton HF press for free from a buddy making room in his garage.
Works awesome for leaf springs, sway bar bushings etc.
Man it makes like easier . When you need it you NEED it!!!!
Sent from my SCH-I545 using Tapatalk
619DioFan
San Diego , Ca.
For the money the HF 20ton press is hard to beat. you may find a " better" one used on craigslist but it may take a while. you can usually find the 20ton for 159.00. I would go with the 20. I have a 12ton that works but sometimes it takes all it has.
toplessHO
central florida
rule of thumb is a floor model should be 100# for every 10 tons
not including a jack or any plates. I dont see the HF one weighing in at that
hotspaws
if you live where they use salt get at least a 20 ton or stronger anything else just won't cut it for any kind of bearings that press into knuckles. you won't regret having a too strong press but for sure you will if it is too weak
