merlinpro
Hi Guys...
Quick question...
I had my floor poured this morning
after waiting because of weather. It was poured @ 3500LB and reinforced (fiber mesh I believe?).
I will be ordering a HD 9 4 post lift in a day or two, and the place that the lift will be comming from (once floor was poured then that was the go to order lift!) said to have at least 3000LB.
Just checking with the floor experts to make sure I ended up with the right stuff...I know, the floor is poured....but does the fiber mesh make it a little stronger?
We were going to go with 5000LB at first, but ended up at the 3500LB+ fiber mesh, and builder said more than strong enough to hold a 10 wheeler truck.
OH, should say that the concrete is between 4-5" thick.
Thanks. Dave.
Quick question...
after waiting because of weather. It was poured @ 3500LB and reinforced (fiber mesh I believe?).I will be ordering a HD 9 4 post lift in a day or two, and the place that the lift will be comming from (once floor was poured then that was the go to order lift!) said to have at least 3000LB.
Thanks. Dave.
