I rented a single head Husqvarna PG280 and 6 30 grit inserts. I grinded dry. I am about 1/2 way through grinding the floors once and have hit a road block.
I have two areas that I'm preparing for the High Solids DIY kit:
1. New Concrete 3 months old
2. Old Concrete 1988
The first section (180 sq ft) went about as I expected and didn't wear the inserts too bad. Maybe 1/4 down.
The second section with the old concrete was about the same square footage and wore them down completely.
I have two questions:
1. I have attached the pictures of the old concrete after grinding. The concrete looks pretty rough. Does this look right to you, or will this concrete be a bad foundation for the epoxy kit?
2. Should I expect to go through an entire set of inserts within 300 sq ft, or is that abnormal?
Before I continue with the job, I want to make sure I'm on the right track, and don't want to dump another 150 dollars on inserts and apply the epoxy if it's doomed to fail.
