Floor under cabinets?
mbmb
Houston
We're in the middle of putting Racedeck in the garage / workshop, and my assistant pointed out that it might make more sense not to put flooring under where the cabinets will be (I thought we would floor the whole workshop and then put the -very heavy- cabinets atop the flooring).
Any thoughts one way or another? I'm going to have to make a decision very soon -- like in the next hour.
Thanks,
Mark.
XR7G428
Fountain Hills, Arizona
Use cabinets that hang on the wall. The space under the cabinets is very useful for long stuff. It is also easier to hose out the garage.
Thanks,
Mark.
sayemthree
for race deck that would make sence , for epoxy
I would (and did) the whole floor first. many of my cabinets are up off the floor too - but not all.
mbmb
Houston
Thanks for the replies. The cabinets weigh several hundred pounds empty. I don't think I'm going to be hanging them off the wall.
bmwpower
May be too late, but I would put the floor down first, then the cabinets on top. For one thing, you can hide the cut pieces behind the cabinets. Also, if you ever want to reconfigure the cabinets, you're stuck.
Racedeck should be able to handle the weight. If it can handle the weight of a car, it can handle the weight of a couple hundred pound cabinet. Also, remember, the weight is distributed over the floor tiles.
65vetteracer
Remember to let the floor settle and get to temp before placing heavy objects on it, or it will buckle. The hanging cabinets do work best if that is an option
Good luck
Scottydog
I'm at teh same stage, about to put down racedeck. My slide-lok dealer said put the cabinets on the flooring, even with the legs slidelok comes with.
