LegacyIndustrial
Pap is hard stuff and does not like recoats. You may have to use a grit pad vs. the screen in order to break the surface properly. If you have non-skid involved it makes this tougher yet.
Wipe it clean with denatured alcohol once done sanding and make sure its properly profiled.
Lastly, imo, its better to stick with like coats. Pap over pap, etc...
I get the sense that polishing and sealing is going to last and protect way longer than the top coats.
