flooring ???
BC iron works
will a 2 part epoxy floor stand up stand up to sparks from welding and cutting
dcs Inc
Indianapolis, Indiana
No it wont. Not much out there that will as a topical. You might want to think about a polished floor or purchase some welding mats for the area you are welding.
gene ec-Indy
LegacyIndustrial
deerfield, IL
If you are looking for some color, you could "acid stain" and treat with a densifier.
The densifier will not add any topical sheen but will eliminate dusting and add strength to the surface.
dcs Inc
85 camaro, It that the welding mats that will burn through? I'm not a welder... well I try not to be and thought that was the way to go. gene ec-Indy
LegacyIndustrial
deerfield, IL
OP needs to clarify welding or torch cutting. Welding is not bad if not done right on the floor. Cutting with a torch produces red hot slag that sits and burns.
Grinding a piece of steel can create a hotter spark than the welder will.
Falcon67
Merkel, TX
I welded a lot over my epoxy floor and never worried about it. If you want the floor to stay pretty perfect, then use blankets. Otherwise, let it be a floor.
tncatadjuster
Memphis, TN
+1 never an issue, just a few light spots.
