Flott 604 1940ish Drill Press
1982fxr
Phoenix
What country are you in? Nevermind just saw your name.
That's pretty sweet.
whateg01
doo dah, kansas, usa
Interesting that it would use flat belts that late. My Craftsman was a 1937 machine and it uses vee belts. My 1947 WT 1100 uses vee belts as well.
Garcky
Twin Cities Metro Area, Minnesota
That will be terrific, once it's cleaned up. Flat belt, though...
It could be difficult to source a new belt for it. Still, you could probably find v-belt pulleys for that nice drill press.
dutchgray
Dorset. England.
Flat belts are easy enough to get, there are even modern kevlar based belts that last a very long time. Just got to find the specialist suppliers on the Internet.
whateg01
I believe it was an leather belt.
I ordered according to the old belts length, which turned out to not be the correct size.
Anyway, Its mostly done now. Will post some pictures later.
I believe Dutch was saying you can replace old leather belts with modern materials like those made with kevlar. My old lathe now uses a serpentine automotive belt inside out.
dutchgray
Dorset. England.
I was.
Modern automotive belts (either multi rib or timing) used backwards or with some time spent flattening is a good and cost effective option if you can get the size you want.
Cleave
Back Porch
I got a custom length flat belt for an old lathe on ebay, pretty cheap.
Great looking machine too!
rustyzman
Chicagoland
I was.
That trick can work particularly well if you use a Continental serpentine belt that has the textured backside. It is a grippy surface. Not all Continentals do, but there is an advantage there with that design in this application.
Just a thought
