Flow meter style or gauge for Argon/CO2 regulator
mogandave
Bangkok
What are you going to use it for? If you're running CO2 and welding a lot, buy one with a heater.
manac
CT
They both work and will get you in the ballpark. The dial gauge type are calibrated to a fixed gas and orifice combination. The ball type are measuring actual flow to the gas listed on the scale. They typically have three scales for different gas/mixes.
I like the ball type better but I end up setting my flow to the weld.
welder4956
Birmingham, AL USA
I like the ball type flowmeters as they seem to be more accurate and you have a visual indication when gas is flowing. With the gauge type, the needle doesn't move when gas starts or stops flowing. If the hose gets pinched or the bottle is running out, it is not as obvious with the gauge type. It is really just a matter of preference, either one will work fine.
BigMike782
Either will work. Flow meter is usually more accurate but slightly more expensive.
Flow gauge works fine for MIG because flow rate isn’t that big of an issue.
Flow gauge uses a metered orifice and a matched gauge to determine flow.
Monza Harry
Windsor ON
Oh! I see since it was so low ~0-25 l thought it was flow as well.
No just F#$%^^g metric! 1 Bar = 14.7 #/"square. I'd look for an pounds version. Also the dual gauge version is a little more robust than the flow meter. Minimal but tougher I feel. More fodder for additional "Analysis Paralysis" Harry
mogandave
Bangkok
Thanks, so the profax is a decent one?
Or pretty well any of the ones on Amazon for ~ $30.00, as long as they say Argon?
Some say Argon and CO2.
We ran Harris at work, but were I in the market for something at home, I would order the ProFax.
For $10 I would not buy it from Amazon. Do you have your bottle yet?
bubinga
LOL 14.7 is easy to remember, perfect gasoline to air mixture.
Analysis Paralysis :LOL: :):LOL:
bubinga
We ran Harris at work but were I in the market for something at home, I would order the ProFax.
No bottle yet. l thought l found a "deal" online, but you know how that goes. l think it's a scammer site.
Where is the cheapest to get a full argon tank? l don't need a big one.
mogandave
Bangkok
I would try to buy one from whomever you're going to have fill it.
Do you have the welder yet? Often a decent MIG unit comes with a flow meter.
bubinga
bubinga
It's not here yet.
It doesn't come with the gauges.
I know it's not a Lincoln or a Hobart, but this
looks like a lot of welder for a beginner, for $350.00. Reviews are good.
I'm going to give it a try. l can't afford a $2,000.00 welder. https://www.amazon.com/dp/B0B1TGZ8XN/?tag=atomicindus08-20
mogandave
Bangkok
It's not here yet.
Look like a nice unit, you should have fun with it. See how you like it with flux-core and worry about your gas later.
Make sure you can buy the consumables for your gun before you need them.
bubinga
l found what l think might be a decent price on a 45 CF bottle online for $64.90.
I'm not sure if it's free shipping yet?
Will the local welding shops usually exchange this tank for a full tank of Argon without issue?
Would this be a good deal for a 45 CF tank?
Pretty sure it's a CGA 580, waiting to hear back from the company.
bubinga
IDK maybe a nitrogen bottle is not suitable for Argon.
Maybe it is though, this one on Amazon says Argon-Nitrogen-Helium.
Walkers
Cave Creek Az
Just buy one locally. My LWS has decent prices on them, the take care of recerts, and I can upgrade the bottle just by paying the difference.
BigMike782
45 cf is an odd ball size in my area. I would buy one from a local supplier so you know it's a size you can exchange. It's also good to have a contact at a welding supply. As you buy product and get to know them and they get to know you the chances of better pricing are better.
86turbodsl
Just my opinion, but cheap chinese regulators are a waste of time. You can buy a quality used one on fleabay for about same price. Harris, Victor, something decent. The ball style is much more accurate if you really need a flow meter. I use the gage style on my mig, higher pressure is usually needed for the long mig whip and to get gas out there fast enough. My tigs all have strike delay to get gas to the cup before it starts the arc. Mig won't have that.
BigMike782
As long as it's a CGA 580(inerts) and not 320(CO2) you're good to go.
Harris is a good brand so are Smith and Victor. I have a couple of Concoa and they are real nice but are pricey.
Jack Ryan
Adelaide, South Australia
What style is preferred? Or does it just matter what l prefer to look at?
I prefer the flow meter (with the ball) myself - it shows flow only when there if flow, a flow gauge shows a higher flow when there is no flow. I use them on MIG and TIG.
The one you posted has to be used with a side entry bottle - be careful with that.
The one you posted is calibrated at 50 psig. That means there will be a significant surge when you pull the trigger. You can get used to it but it can muck up your starts. A better one will be calibrated at (say) 20 psig
That's my 2c worth.
Jack
86turbodsl
What Jack said. You're going to get a big surge of wasted gas at 50psi. The higher pressure are appropriate for mig. you want low pressure for tig, since you have preflow time before the arc strikes.
