Fluid Extractor
boom_bap
Idaho
Hey folks,
I'm looking for a manual pump fluid extractor. I don't have shop air so manual it is. I plan to **** trans fluid out of the dipstick, so that when I drop the pan I don't take a bath in ATF. I've seen OEM, harbor fright, and mityvac make a few of these. Anyone have any recommendations or garage hackery.
4xdog
Santa Fe, NM
I have experience with two kinds.
Blackstone Laboratories' oil transfer pump, aluminum-bodied and US-made, works great. It's designed to work with polyethylene refrigerant tubing, and transfers fluid (oil in the case of Blackstone, but it'll work with just about anything) into a container screwed into the pump housing. The threads are standard, working with a Blackstone sample bottle but a lot of other things around the house, too.
Griot's Garage siphon pump. They brag about this one and it apparently gets good ratings. Not from me. When used with gasoline the pump swells and can barely be actuated. My questions to Griot's about this in light of its claims that it's safe for automotive fluids went unanswered. Mine sits idle now.
JRC3
Southwestern OH
Menards fluid transfer pump, 16" of 3/8" poly tube, 6 gallon jug placed in an old shop vac to catch drips and make it mobile, oil dry in the bottom. I have longer 3/8" poly for trans fluid through the dipstick and antifreeze through the cap. https://www.menards.com/main/tools/...24-c-9113.htm?tid=-5520598541192341945&ipos=2
20210330_135419-jpg.1485358
And a big funnel for truck/car oil/filters changes.
I have another 6G for antifreeze. I bought 6 of those 6G jugs for 20 bucks on FBM.
matt_i
I've been using the Moeller fluid extractor with success in marine apps. Only on engine oil but I'm guessing it would handle ATF nicely.
ex-x-fire
Sheboygan Falls Wi.
I made my own, works pretty well.
boom_bap
Idaho
I've got a deep 4l60e and mine has a plug actually, but from what I've read about the job, you don't want to take it out because they are prone to stripping out. Then you've got a pan with a hole in it.
Al Borland
Stupid human trick:
Get roll of polyethelyne tubing to stick down dipstick tube. (Home Depot)
Fill washer fluid, take empty jug and drill hole in jug to fit poly tube tightly
Push one end of poly tube into jug
put other end down dipstick tube
get out shop vac
put vac hose end over cap opening, turn on vac
drains fluid faster than expected
Old Man Roger
Palm Coast Florida
Stupid human trick:
get out shop vac
Creative!
dnschmidt
Phoenix, AZ
I've got the manual Mityvac that looks like the one referenced by Formula but doesn't use air but is manual. Works for me. These other pumps seem much too small to me. We are talking about like four quarts of fluid here. I'm too lazy to pump these little guys that much.
infinite97
Vancouver, WA
Any cheap transfer pump with a spool of tubing would work for what you need.
i have an old fuel pump from a small engine we replaced here at the shop, I put small 1/4” tubing in both sides and alligator clips on the pump wiring. Slap it on to the battery and pump away.
Formula
+1 for Mityvac. Pump it to a vacuum and go get a cup of coffee.
They work great for removing or adding fluid. I keep one with just trans fluid that I can **** out through the dipstick tube, get an exact measurement, and put the same about of new fluid back.
msharley
Central Pennsylvania
Why transmission pans don't come with drain plugs I'll never know. At least you can put one in once you have the pan off.
Silly you!
That would cost them ten cents per car!
The shareholders are HURTING, don't you know....
The Board Members would only be able to give themselves $349 Million Bonuses.......this Quarter...
mikegt4
sw ohio
I have always heard that it's to keep people from just changing the fluid and not taking the pan off and changing the filter. That being said I put a drain plug in the pan at the first fluid/filter change on the only auto trans vehicle that I ever owned. Sure beats swimming in trans fluid at the next service.
vssjim
McLean Va.
I actually have new GM drain plugs for these in stock because if they come out and start to tear up it gets a new one because torx hole is shallow
blazemaster83
Lacey, Wa.
I use this one at work, on boats. It works great. Give it like 20 pumps, and you can basically walk away, it will fill itself and shut itself off when full. It comes with a few sizes of hose, down to really small. I have used it a few times right down the dipstick hole.
B_Bimmer
Eastern Iowa
Stupid human trick:
get out shop vac
Protip: don't use this method with gas.
