Fluid transfer hand pump
tacomabob
What is a good fluid transfer hand pump for filling transfer cases and rear ends ?
I saw a Plews 55001 that looked good. What are people using ?
Sureshot
Bridge Creek, OK
I have had the idea of putting a small oil pump(small enough to fit in a pail bung) and drive it with a drill or driver to pump oil. Any one know of a small enough gear pump?
I built one with an automotive oil pump that goes in a 22 gallon plastic drum and it works great to **** or pump. It is my used oil catch and I can pump the oil out into 5 gallon pails to empty it or use the hose to **** the oil out of a container used to LOF a semi or anything else that doesn't go on the hoist.
I also built an oil sprayer out of a 20lb propane tank that had a fill bung and siphon tube added and uses air pressure to spray canola oil through a garden spray nozzle. May have to make one for 80-90.
Dust
Santa Ana, CA
I want this one but the cost is making me hesitate. However, I'm sure I'll have one too many one night and end up ordering it in a drunken shopping binge, as well as two hundred dollars more in tools that I absolutely must have, and end up loving it so much I'll wonder why I waited in the first place.
