Dillithium
- Joined
- Dec 14, 2011
- Messages
- 151
Hello All,
I've been eyeing multimeters for a while now, and never really thought about Fluke since they are so damn expensive, and as a DIY I can't really justify a 500 dollar DMM. I've never really looked at the prices of their 110 series however, and they are pretty affordable.
They don't have the wide range of functions the 80's and 280's have, but for me it's good enough I think. I'm looking at getting the 115.
I basically want it for motorcycle, automotive(nothing complicated like RPM measuring, or scales etc), and homeowner (110/230V) and small electronic stuff, ranging from 5-12 volt.
In that range I'm looking for resistance measuring, DC/AV volt measure in volts and millivolts, and Amp measuring with a milli-amp accuracy. I'm really not an experienced DMM user, so I will not be using any fancy options like capacitance or true RMS but I don't want to have to replace mine if I ever do find the need for something like that.
Basically, would the 115 suit my uses? Or would it be wiser to spend the little bit extra for the 117 or even higher? Or are my desired uses so simplistic that Fluke is a waste of money for me?
Also, the Ohm scale seems a bit on the high side on the 115, it says the range is 600 ohm to 6 Mega ohm. Is that a good scale that will be able to do it all? it seems to me that 600 ohm is a bit high to start with, especially if you use the resistance feature to check for wire breakage.
Any advice or schooling on DMM's would be appreciated, I searched but the 110 series has not been discussed.
