signcrafter
- Joined
- May 9, 2012
- Messages
- 12,630
That wouldn't cause them to be off that much, I don't think. Since I can't sleep, I calculated the max and min respective of their manufactures stated accuracy includin LSD error.
Meter Measured accuracy (VDC) High Low
fluke 16 12.44 0.9% +1 0.009 12.55 12.33 12.56 12.32
fluke 77 12.44 0.3% +1 0.003 12.48 12.40 12.49 12.39
fluke 87 12.67 0.05% +1 0.0005 12.68 12.66 12.69 12.65
BP 12.59 0.5%+1 0.005 12.65 12.53 12.66 12.52
So for a not so smart guy like myself what exactly do these numbers mean?
Here are some of my meters comparison. 2 Fluke, 4 HF, and 1 CM. Lowest (9.96 V) to highest (10.08 V) is about 1.2% difference. The 3 free HF meters did pretty well. They are all measuring the same 9V battery. All the meters are bought brand news and have very very little use except for the large HF meter in the background. That one has quite a bit of usage.
So yours are off .12 volts and all bought new and not used much, even your two flukes are different. Mine are a little more off at .23 volts. But mine were all bought used. Am I just being to **** about all this? Are all meters off a little if you don't get them calibrated every year or what ever the recommended time frame is? Should I just quit worrying and use them as is and everything will be fine? Is there ever a time in automotive work where .23 volts difference when measuring 12 volts will be an issue?
Useless measurement and poor idea.
