junkyardwarrior
- Joined
- Nov 17, 2014
- Messages
- 176
I am in the process of trying to figure out my lighting. 30x40x10 pole barn w/concrete. 200A dedicated service.
Right now I have 10 T8 fluorescent 8 foot fixtures screwed directly to the bottom of the exposed trusses, and I need to wire all of them. I don't plan on finishing a ceiling, but do plan on finishing the walls. There are 3 rows of fixtures. Center, south end and north end. All 3 will be on separate switches so I can turn on a row at a time as needed. Most of the time the center row is all I'd need (already verified light output).
I seem to remember reading code on this, and seems like I remember that if the fixtures are mounted direct, they require conduit. If suspended (chain, cable, etc) then they wire can be exposed. Is my memory correct?
Do you guys have any similar situations where you have the lamps mounted directly to the trusses? What did you do, and does anyone have a photo of their setup?
