The label of a ballast will have some good info on it. Some older magnetic ballasts did not have temperature protection. Combine that with the lower efficiency and heat from failing bulbs and you can have a problem.
Any off the shelf ballast you purchase should have a UL / NRTL logo on it. (NRTL is nationally recognized test lab)
Significant things to look for:
Residential or commercial:
High frequency electronic ballasts have to meet FCC part 18 rules for EMI.
In those specs there are two categories, residential and commercial. Residential ballasts have tighter EMI standards.
EMI might matter if you are trying to listen to very weak radio station. I have a commercial fixture in my home shop... No noise issue's.
Why would you ever use a commercial ballast? They have power factor factor correction.
Power factor might matter if you have a lot of lights on one circuit. Both will draw a similar amount of power, but the apparent power is higher on a residential ballast. Basically, you can't run as many lights on one circuit.
Ballast factor: Ballasts come in several ballast factors. That controls how brightly the lamps are lit. I recently upgraded a fixture that had a .87 ballast factor with a unit that has a factor of 1.2. It was a pretty dramatic difference and helped out in an area with wide fixture spacing. With florescent lights, ballast factor is not a major factor in lamp life (On off cycles and starting method is a factor).
On the label you should see a "Class P" rating. That indicates that the ballast will shut down if its temperature goes above 105°C.
If a fixture overheats it shuts off... Tested by UL.
View media item 34159
http://www.garagejournal.com/forum/showthread.php?p=3542550#post3542550
Ballast Upgrade Post
