Flush Cutter Recommendations for Plastic Tabs in Circular Hole?
YoshiMoshi3
Can someone please recommend some flush cutters for plastic? I'm trying to cut off these four plastic tabs in each circle. The circles are about 21 mm in diameter (slightly larger than). I don't know if "special" flush cutters would make it easier for me, where "flush" is a circular surface instead of a flat one?
PCustoms
VT
How many do you have to cut?
1/4" Template bit in a router table is what I would do.
larry_g
oregon
A lot depends on the required 'look' after tab removal, the material the product is made out of, and how many you have to do. Do you need to remove just what protrudes into the circle or also what protrudes below the circle? Me for limited amount and soft plastic I would use a set of flush cutters.
Old tool guy
Ah I don't have a router table. Flush cutters is a no go?
I need to cut 120 circles so 480 tabs, yikes.
Don’t need a router table. Get a small palm router and a 1/4” bottom bearing flush cutting bit. Once the depth is adjusted, you’re looking at about 10 seconds per cavity.
Y
YoshiMoshi3
I only need to cut what protrudes into the circle.
PCustoms
VT
You cutting flush to the ID, to the surface or both?
Is this a hobby project or rework/degating a molded part?
Y
YoshiMoshi3
Hobby project. I'm cutting the tabs off. So that way I have a 21 mm circle.
The circles are 21 mm but there are four plastic tabs that stick into the middle.
Y
YoshiMoshi3
Ah so a palm router and a 1/4 " bottom bearing flush cutting bit that is 21 mm in diameter would work it seems?
PCustoms
VT
No
That would be a huge bit, hard to control
Something like this:
Depending on the part and how you're going to orient it you might want the hearing on the order side.
My hesitation doing this freehand we would be keeping the router flat. The table spreads out/supports the uneven surface of the part
T444e
I have a Knipex 45 degree flush cutters that I use on cable ties that work well. That style may work for you but I don't know the model number.
Old tool guy
Thought of that. The hole is only 21 mm dia … 7/8” … the router base plate is going to span much more than that.
KnurledNut
n/a
Mini flush cutter bit in a router table. Fast and accurate.
1/8 shank:
1/4 shank:
Rabid Badger
If you have a 3d printer you could print custom cell spacers rather than modify those.
GeoBruin
Only works if the bit is exactly the right size, and is aligned exactly right. Not likely to be a success.
He knows the ID of the holes and can purchase an appropriate bit. He can align it exactly by starting the bit through the other side without the tabs. The hole will act as a guide for the bit.
sparky 1971
Central Iowa
How about running a hole saw through from the other side? Of course, that is dependent on the right sized saw existing.
Looks like the above poster beat me to it.
The Cobbler
how hard or brittle is the plastic?
I'd be trying to find a cutter of some sort to punch them out , like a pc of pipe sharpened or a curved chisel etc.
as mentioned, a hole saw , forstener bit etc. a heated knife to cut them .
a 3/4" hole saw, or even a step bit.
then clean it up with a sanding drum on a drill
PCMusicGuy
Houston, TX
I've had good luck with Xuron cutters in terms of performance/dollar. Depending on the thickness of the tabs, you may be better off with a small hobby knife or hobby saw with a flexible enough blade.
