Lt CHEG
I recently acquired a 1999 2 door Tahoe 4x4. I’ve been lusting after one for over a decade and I found a solid rust free truck recently that’s now going to be a build project for me. The dash board is cracked as is typical of that era GM truck. I plan on buying and installing a Dashkin cover as I think that’s the best, most durable long term solution. However, before I install the dashkin, I’d like to stitch together the existing dash, since it’s just cracked and there are no missing pieces. I figure that a structurally together dash will also make for an overall better installation in the long run as well.
So I plan on purchasing one of those plastic repair stitch guns (I’m open to suggestions on those by the way as well). It’s the type that heats up a metal staple like object that is then pushed into the crack and permanently joins the two pieces of metal together. In order to clip off the remaining metal “legs”mod the stitches/staples, I was thinking of using flush cutters like SnapOn model 786CF to get the nibs cut flush with the dash before installation of the dashkin. I know these cutters are supposed to be for flush cutting zip ties, but would they be adequate for cutting those staples/stitches as well? I just figure they would do a slightly better job than my diagonal cutters, even my SnapOn Vector Edge ones, leaving less prep work before moving on to the next step. I’d appreciate any feedback or suggestions. Thanks!
