Flux Core Welding
Phil S.
I have been using a Hobart 110v Flux Core welder for 20 years. Why is Flux Core welding considered to be a less desirable weld than gas shielded? Thanks
Copymutt
Colorado
One limitation is the use on sheet metal/automotive.
Flux core is just too much of a good thing here. Shield gas and smaller wire gives the control you need w/o burning through.
Flux core permits higher amperage. Combined w/ 035 wire you get better penetration for thicker work.
Flux core also leaves more slag than gas shield.
Jim
Kaizen
New England
It has its place on 110 machines. I don’t use it for thin stuff due to the mess and always smokes up the shop bad. If I go to 1/8 material I always use flux as my little machine can’t put out enough heat with gas settings
01-7700
Maine USA
If you're happy with the results you're getting with flux core, I wouldn't be too concerned with what others are saying about it.
Mr_fixit
Rustylvania
Try a mig and you will probably never want to use a flux core wire again. Cause the welds look like ****.... Relative to MIG..
