I'll add this to flux core questions.
I only learned about this a few years ago from our welding supplier. Most flux core wire also has a seam from forming that can allow moisture penetration to the core. That rust contains both oxygen and hydrogen...neither of which is good for a weld.
I'm currently borrowing a flux core welder and had to change out the wire because I'm getting ****** results and worm-tracks. The tracks are likely from humidity the core absorbed because 1) the welder/wire doesn't get used or stored in a climate controlled garage and 2) it's had the same 10# spool on it for years.
Fixed the issue I was having by getting a 1# spool. It's also been very humid here so after I'm done, I trim the end, respool the wire, and put it in a ziplock bag since I'm only using it on small projects every few weeks.
As for the OPs new wire still puttering, along with the above suggestions, have you tried a higher angle? I'm almost vertical during my backdrag on a flat surface, definitely not more than maybe 10 degrees. A couple t joints I recently did for a neighbor I was maybe 30 degrees on the backdrag and got decent result and very little splatter/sputter.
V/R
Bogie
