wishin4snow
- Joined
- Aug 1, 2023
- Messages
- 3
I have a 36x54 pole barn in PA. Eventually I would like to add insulation to the building. This is something I plan on doing myself. I have been trying to research what I can and like the idea of using 1.5" foam board between the girts and spray foam the gaps. I would later add more insulation to get a higher R-value. Not sure if this would be 2" foam board or batt rolls. Either way, my question is if I need a vapor barrier on the walls. From what I can gather, I don't because the foam board.
I would eventually like to add some sort of HVAC system to just keep a comfortable temperature. For example, 55 degrees in the winter.
Looking for suggestions.
