r00a005
I have been thinking about adding a hanging shop heater to my garage (about 1000 SF), but it would seem prudent to first think about insulation so I can assess total cost. Right now there is no insulation. The walls are OSB with wooden siding. The garage has about 2 car bays with a "flat" trusses, with one bay having sloping trusses to accommodate a car lift. I was thinking about laying 4x8 sheets of foam insulation on bottom portion of the trusses, and at least the tops of walls. Its pole type construction so the walls are fairly easy to do. I also have fans that can direct heat downward. I am located in PA outside of Philadelphia.
I see 4 x 8 sheets at the local stores to have R values of 10 or 7.7 at the most.
Will doing this provide any significant benefit, or is the R-value too low ?
Thanks
Bruce
Thanks
Bruce
