Foam board over or between girts?
Lucky-Ducky
Does it matter if EPS is installed over the girts instead of between them?
The pole building has housewrap between the metal and girts/purlins.
Would the 1.5” air gap cause any problems?
L
Lucky-Ducky
I actually did both. 👍
But no, that gap won't matter and might result in a "tighter" building even with wrap.
I have enough foam for 3 layers. I am debating between the girts and then stacking 2 layers or just doing 3 layers over the girts (staggered joints on all layers).
CraigStu
Blacksburg, Va
I can't imagine fitting it between the girts. You know they are X inches apart +- an inch. I would bet you end up either cutting the foam or leaving a gap for at least half of them.
L
Lucky-Ducky
I would cut the foam to fit between the girts and either tape/foam-fill the gaps
cmandp
New Jersey
Over the girts would help create a thermal break as well. No direct path from outside to inside.
NUTTSGT
Northern Central Ohio
If I had that much foam, (guessing you have 1.5" foam) I would put a layer between the girts before the metal goes up. The the the other 2 layers on the inside, alternating joints/seams.
I'd cut, or at least attempt to, with a table saw outside. If the girts are spaced appropriately, you should have to make no fence adjustments.
PWC Repair
Arkansas
Mine is all between the girts WITH an airgap to the metal. My ridge is vented and the small eaves have some venting as well. At some point I'm going back over the ceiling from the inside to cover the purlins up but haven't done it yet. I've been working out of my shop for about 8 years now and am CONVINCED the air gap helps A LOT in the hot weather. Pics and info are in my thread below.
