My new steel garage is sweating like mad ... the roof is insulated but the walls are not. I'm planning on insulating the walls with 1/2 inch foam sheeting from Home Depot. Cost is reasonable at $13 per 4x8 sheet. The sheeting apparently has a vapor barrier on one side. I'm most concerned with keeping the moist air away from the cool steel walls which causes condensation. I live in the Florida panhandle and we do get some cold weather in the winter months. I'm not concerned over heating or cooling issues as much as the condensation problem. I plan to use panel adhesive to bond the insulation sheets to the metal siding after snugly fitting it between the steel studs. Any comments?
