Deude_Mann
So I have some backed fiberglass batt insulation I will be installing in a metal building retrofit style. This is batt insulation that has been bonded to a strong, reinforced backing material that holds it in position. Think of it as taping kraft paper insulation to a ceiling or wall stud.
The usual method of installation is to tape the tabs in place with something like 3M 514CW double-sided tape...
https://www.3m.com/3M/en_NG/company-mea/all-3m-products/~/3M-Venture-Tape-Double-Coated-PET-Tape-514CW-48-mm-x-50-m/?N=5002385+8709317+8709365+8710676+8710815+8711017+8713638+8740726+3292746306&rt=rud
However this is a thin tape that does not provide a thermal break between the metal purlins and the metal panels I will be adding to the interior walls after installing the insulation. I would prefer to use something like double sided foam tape to provide a thermal break and am shopping around on different types right now. It MUST be double-sided tape for the way the batts are attached.
Do any contractors or people with experience have a suggestion for double-sided foam tape that will work, and is not incredibly expensive like 3M VHT (which would be overkill)?
Thanks in advance
Thanks in advance
